I am doing a tbi conversion on a 9/77 fj40, so I had to buy a large cap distributor. It came in the mail today so how do I install it? I'm just not sure of the proper oreintation.
That works great.Static time it with the engine off first:
Put the engine at 7 degrees BTDC for cylinder #1 by manually turning the engine until the pointer is at the BB and the rotor is pointing to the spark plug wire for #1 (and not #6)
Then retard the distributor 20-30 degrees, put a test light or volt meter on the distributor wire (or coil - lug, same thing), then turn the distributor CCW until the light goes on or voltage jumps up.
This will be close enough for it to start and run. Then you can adjust it while it is running.
