69vortec
SILVER Star
Does anyone know the length of the JT Outfitters brake booster adapter that clears the rib on the early FJ40s?
The pic above is not a early model FJ. I have a 69 and I dont think it will clear. I am planning a f60 booster with an extension adapter for mine conversion to front disk.
The JT Outfitters adapter is 3.25in long. I ended up making my own at 4in for use with a 1998 Tacoma booster and master cylinder.
I'm trying to figure out the best/easiest way to boost my '70 without cutting the stiffening rib. The JT Outfitters adapter looks like the right idead, but a little pricey at $60.
Can you post up some pictures of the adapter you made? I'd also like to see how the Taco booster and MC fit! The '79-'83 mini truck booster that JT Outfitters recommends is expensive and hard to find, but a late-model Tacoma booster ought to be easy to find in the junk yard.
Brian
I just built an adapter for the '79 mini truck booster to install on my '65. Pics attached. The booster came with an aluminum spacer and steel plate. I used the steel plate as a mounting plate for the adapter, as it already had the right hole pattern, and just welded it to four plates and a face plate with the original 3 hole pattern + a big center hole. I placed the booster/MC up on the firewall and measured how much spacing i'd need, happened to be the same as some flat stock i had laying around which I used for the four side plates. Worth mentioning I have a SBC so length wasn't a real concern, but I also didn't want it any longer than needed to clear the rib. Sorry no pics of it all installed as I've found that the booster now heavily rubs the clutch master cylinder (which wasn't installed at the time of fabrication), so my works not done yet... I will use the aluminum spacer still. FWIW my adaptor is 2 1/4" in length, and the aluminum spacer is 1 1/4" in length, so call it 3 1/2" total.
