Hey guys, i figured why not make a thread on this conversion since not so many people have done it. Anyway, i'm installing everything little by little, hoping to get it done in less than a month, only have weekends to work on it cause of school and work. So its gonna be a little slow.
First things first, got a throttle body, wiring harness, and computer from the yard.
Also got the airbox stuff.
Map sensor and the ecu module.
Wiring harness out of a 90??? s10
Connection to computer
One is a fuel pump relay and other is ac relay.
I think this is the reccomended computer.
Cut this hole in the firewall with some cutting tool
Temp sender
Ooooo this is going to be fun.
Map sensor
Well that's all i've done so far, i purchased the downey kit, but am already seeing many things that i am going to return because i already got them from the yard. The vss, igniton module, coil, fuel pump and a few other things didn't come in yet cause Jim didn't have them in stock, no biggy. So i didn't have much to work with. Anyway i'll keep updating as i get s*** done, peace
Temp sender
Map sensor
