Hi, This is my first post on here. Glad to be here and I already enjoy the site to get good info.
I've got a 78 fj40 and I just replaced the master cylinder, front calipers, rear wheel cylinders from CCOT and brake pads and shoes as well. I bled the maser cylinder first, then the rest like the manual said and I'm having trouble bleeding the brakes. the front seems to be doing fine, but the rear still has problems. The brake pedal will go to the floor the first time then come up about a 1/4 for the second, third, forth and fifth pump of the pedal. It will hold when I do this, as long as I don't let off the brake pedal, when I let off the pedal, after a while I go to push the pedal down again and back to the same old thing. What could be wrong?
Thanks alot,
Mike
