Heres the details in case they help: The door lock actuator motor got weak and I pulled the panel, removed the actuator, used a hair dryer to open the actuator, and replaced with a mabuchi motor with the brass collar. All was good and I put a zip tie around the actuator to keep it from coming open.
This is the third or fourth time I've replaced these on LC's so it wasnt a big job and worked perfect after getting it buttoned back up.
Next I tried to program a new master key and you all know you have to "cycle" the locks over and over but I was never able to get the car into "programming mode". Went to the hardware store afterwards and when I got back to my car the rear left door would not open from the outside. So i reached inside and tried the inside handle and it wouldnt open the door.
I never checked the child safety switch after the actuator motor repair.
So i went to a locksmith and three guys tried for an hour and never could get it open. Then called pop a lock and that guy couldnt get it open.
If you press the auto lock and unlock button the red and brown indicator on the inside moved open and closed like it should so I assume the rod that connects to the yellow plastic clip must of come undone.
Anybody got any ideas on what I can do?????
