Here is an interesting one...tried a search and only found 80 series info. I have been replacing my door actuators thanks to (jonharis)...and got myself in a pickle last night on the drivers side 2nd row door.
After replacing the actuator motor and reassembling (everything appeared mechanically to go back together ok), electronics worked (lock lever moves when actuated, etc)...I shut the door and went through several lock and unlock sequences with the remote and drivers door lock buttons. Went to open the door after unlocking...cannot open the door?! Something between the lock and the actuator must not have been re-installed?
Anyone have an idea about how to get this door open now? Do you think I can get the interior door panel off with the door in the closed position? (haven't attempted yet...ran out of time) Should I be trying a coat hanger/slim jim setup from the top? Thanks for your help!
Andy
Andy
