The joys of dissimilar metals reactions and the parking brake bell cranks. This one was corroded to the point that if I set the brake it wouldn't release and was dragging the brake shoes. And I hate working on parking brakes, those dumb springs that like to shoot off to the far corners of the garage.
I need to train one of my kids to do pictures, but here's a quick how to:
- order new bell crank arm, crank holder (make sure you've ordered correct side for these two - L is driver's, R is passenger), pin, and c-clip for pin (apprx. $30 for all)
- remove wheel
- remove 17mm bolts holding brake caliper on
- hit rotor drum with BFH working your way around until it releases
- undo springs (3) holding shoes in place and bell crank (2)
- remove rear parking brake shoe
- pull pin from e-brake cable from backside
- pull pin from bell crank on front side, if you've ordered new parts consider adding in a new horseshoe c-clip that holds this pin, it's easy to mangle the one on there
- undo two 12mm bolts holding bell crank and remove
- assemble new bell crank
- remove rubber stopper from old bell crank and put on new one
- remove rubber boot from old crank, put on new, adding grease to new pin under boot
- reassemble in reverse
Here is the one pic I did snap, showing the corrosion. It's been this way on 3 LC's I've owned, either Toyota needs to use different materials or I need to use my e-brake a lot more.
- remove wheel
Its really the only maintenance intensive system on a 100. Probably jinxed myself with that one.
