Has anyone out there done or had any custom tuning? Is it not needed due to the "fly by wire" characteristics of our trucks and the variability of the ECU?
I don't know squat about engine tuning but after reading your post I now am wondering why Toyota didn't just tune those dips out to begin with? I mean this is their flagship vehicle and all. I wonder if it was baselined like it is in order to meet govt. regulations on fuel efficiency, emission requirements or something similar.
I seem to recall on a Disco I once owned my LR mechanic telling me that the timing was slightly retarded in order to meet US import emmissions requirements. One of the first things he did was advance the timing and it was like driving a whole different vehicle. Could something similar be the case with the LC?
- Sent from a very small supercomputer.
I also believe this to be a timing issue. Looking at the AF ratio on the 4 wheel dyno, it is a constant 10.73. Meaning it is not fuel delivery so therefore, it must be timing which could have quite possibly been dicked with for emissions. What really tweaks me is the fact that there is about a 50 ft lb drop in torque in the low RPM band! WTF! (sorry, just venting my frustration) I just feel as though there is a whole lot to be gained in this engine through a better tune, just need to find the means and hoping to find some experience.
Also, as far as the AF ratio goes, the stochiometric ratio is 14.7 when in reality, 12 is best due to burn time characteristics. The AF ratio on the dyno plot shows it running richer than necessary. An AF ratio correction could bring the economy of this engine upward and not have to sacrifice anything.
I also got this idea from a friend with a BB tune on his 5.3 silverado.
Any toyota mechanics/ engineers/ diagnostic guys out there?
x2. I was about to say that I was pretty sure there are commercially available tuners for the tundras. Any really good speed shop could tune the motor. It isn't rocket science anymore.I think we need to look at comparable vehicles first like a Tundra, like a Sequoia or even a LS. Most likely the Tundra guys have been tuning for a while.
I would expect 225 at the wheels for a stock VVTI motor on a Landcrusier and the same stock torque as a non-VVTI motor. Having a truck in 2WD vs 4WD will change these numbers.
ChipTorque Performance - Toyota Lancruiser 100 Series V8 4.7L 2UZ-FE
or
Unichip - 2000 Toyota Tundra tuning chip | car tuning
found here Tundra Chip Tuner - Toyota Tundra Forums : Tundra Solutions Forum
here is a result with the VVTi engine...245hp @ the wheels
Gorilla's Dyno results.. POSTED !!! - Toyota Tundra Forums : Tundra Solutions Forum
Probably just semantics, but if HP = Torque * RPM / 5252 how would there be a delta in HP but with Torque being static?I'm assuming you mean peak torque wouldn't change, but that the distribution of the area under torque curve would, with the decay being delayed due valve timing.
IIRC from a previous thread there was an increase in 06 of around 20 (?) lbs-ft. 2007 had a decrease, but this was thought to be due to a change in measurement standards?
I dont really trust those chips, the are uber $$$ and they show bogus dyno plots. I would rather spend that money on a specialist who can take a dyno plot, analyze it, and then tweak what needs to be tweaked. I dont want to have to rely on a canned "solution." It would probably be more work but well worth it in the long run.
I say we just wait for the URD SC kit for the 100......or find a TRD one.......will be way better than a tune could ever dream of being.
