So I stumbled across a VERY used and visibly worn out Warn Series 12 winch on Craigslist. From my understanding, this winch is in their Industrial line and I guess somewhat similar to the M12000 although very different as well. Based on my research, it only has a 2.5 HP motor but is quite a bit more expensive new (this winch is about $1800 new and that $ does not include winch line). I assume that it is designed more for tow trucks and other commercial applications. If any of you Warn experts want to chime in, feel free.
Back to the Craigslist ad. Think winch looked rough, real rough (I can't find my "before" picture as I must have deleted it). The solenoid pack had no cover and you could tell it had been worked on by an amateur. It also did not come with a remote and only had about 50 feet of damaged and rusted cable with it. Basically, the only thing that would come out of this transaction was the actual winch. I drove out to check it out with my jumper cables ready for a motor test. The motor surprisingly tested out great (as best you can tell with jumper cables in someone's driveway). Forward and reverse both worked as well as there was no issue with free spooling. I felt good about the winch and it's guys and forked over my $75, yes SEVENTY FIVE DOLLARS and went on my way with what I hoped was a great platform for a project.
Here are some pictures of the end result (see below for the entire re-build process):
