Your Cooling System & Electrolysis
Saratoga Lake, NY
From the rockauto newsletter.
Scroll down to " Your Cooling System & Electrolysis" this write up talks about the need to change your coolant more frequently but also to check and maintain your chassis grounds with a genius way to test for problems using a multimeter.
Here's the link
RockAuto October Newsletter | Early Edition - https://www.rockauto.com/Newsletter/archives/10-7-21.html#tomStory
I have caught myself thinking, "Why did that heater core fail again so soon?" and then discover the heater core was actually last replaced 10+ years ago. (I avoid losing track of time by using my RockAuto account to see when parts were last ordered/replaced. To create an account, go to upper right corner of the RockAuto home page or look under "Menu" on a phone.)
Electrolysis is the likely culprit when "fail again so soon" is for real, and new heater cores/radiators quickly start leaking. Electrolysis eats away metal in the cooling system and the relatively thin walls of heater cores and radiators are the first to fail. There are two primary causes for electrolysis; acidic coolant and bad grounds. An inexpensive multimeter can be used to diagnose both.
Below are some general diagnosis tips/techniques. Visible dark spots on the exterior surface or the heater core/radiator can be another sign of electrolysis. Consult your vehicle's repair manual (found under "Literature" in the RockAuto.com catalog) and/or seek the advice of your spouse, mechanic, attorney, etc. for more specific instructions.
Typical Multimeter, Radiator & Heater Core
Acidic Coolant:
Old coolant can become so acidic that it begins conducting electricity and moving metal like the acid in a car battery. Take the radiator cap off the cold radiator (so no pressure builds). Start the engine and allow it to warm up enough for the thermostat to open and coolant to begin circulating through the cooling system.
Switch the multimeter to one of its lowest DC voltage settings. Stick one electrical probe in the coolant and put the other probe on the negative battery terminal. A reading of 0.4 volts or above indicates electrolysis is likely happening.
Loose, Missing or Corroded Electrical Grounds:
Now with the engine off and the battery disconnected, again stick one electrical probe in the coolant and put the other probe on a metal engine part (ground). If the voltage is still 0.4 volts or higher with the battery disconnected then old acidic coolant is indeed the culprit and should be flushed and replaced.
However, if the voltage reading is 0.00 with the battery disconnected, then there is a bad ground somewhere in the electrical system. Corrosive electrical current is being misdirected through the cooling system.
Solutions:
Acidic coolant should be flushed out of the cooling system and replaced with the correct new coolant (find Coolant/Antifreeze under "Cooling System" at RockAuto.com). It is often good to flush the system more than once to thoroughly remove as much old coolant as possible.
To track down bad grounds, try measuring the coolant's voltage while turning electrical accessories on and off one at a time. A change in the coolant's voltage reading may indicate the accessory (radio, fog lights, etc.) needs its grounding point cleaned, replaced or relocated.
Tom Taylor,
RockAuto.com​
Here we go again regarding coolant changes…
Do like looking for grounding issues on components failing sooner than expected. That is the nugget for me.
However, coolant becoming acidic from feedback on this forum appears a non issue. From folks with 10y+ rigs who never changed to me owning another brand car being 11y old and having pH 8 coolant from the factory. Be my guest changing it, however the acidic aspects seems a story out there from the past and/or maintenance shops trying to boost their sales.
We aren't exactly seeing many heater core failures in 200s either. Kinds smells like rockauto marketing.
