I assume this is the best section to post this thread, please let me know if there's a better one.
I'm in the beginning stages of installing a York OBA system in my truck, using a York 210 on my 22RE. The compressor is mounted and tested, seems to blow a lot of air, my next task is to get a good solid temporary connection to a spare tank I have, see how well it does at building up air. I did a lot of searching out on the web, now looking for advice from the MUD membership from those that have done this project. Yes, I did search MUD, didn't find much.
1. I'm concerned about the heat buildup on the discharge. I have about 18" of the original AC hose, looks like it has about 3/8" ID. Will it take the heat? Or do I need some sort of rigid pipe for the first foot or so? What about the SS braided hoses that Viair sells?
2. What did you do about a coalescing filter? I know about the Coilhose 8923M that Kilby sells, seems kinda steep, wondering if there is something more economical, although I won't go with anything with a plastic bowl, they blow up eventually.
3. Wondering about the idea of plumbing from the compressor to a check valve, then manifold, then straight to the tank. Use the tank to condense water and oil, then put the filter AFTER the tank, and drain the tank after every use. I have a decent filter on my shop compressor, and I still get a lot of water in the bottom of the tank.
Still not sure where I'm going to put the tank, not a lot of room left.
Thanks!
Thanks!
