yes, you can fit 36" tractor tires on a PZJ70
crushers
post ho
Derwent Alberta
with 2 1/2" lift rear and 3" lift front.
i went wheeling with a few buddies at Lee's Off Road Safari park outside of Edmonton Alberta yesterday.
the front springs need the center holes of the main and military moved ahead 1 1/2" and custom shackles for the extra 1" lift. the rear Beltons actually had 2 leafs removed for a better ride.
the bump stops were extended down 2" to restrict the upward travel for no (or in this case VERY limited) tire rub. the only rub was when i was nose hill down and cranked hard then the tires would rub on the frame but very little.
i will be posting a longer thread in the "international chat" at the bottom later with limited pics.
BTW, i was grinning ear to ear all day with the traction i had even though the front and rear diffs are open.
cheers
sorry this is the only pic i could find with the tires installed on the truck
Geez I'll bet Craig is glad he spray bombed his roof a few weeks ago. It looks downright presentable now.
Those tractor tires look just fine on a small truck. I might have to take a set to ACT2006
Sounds like everybody had fun.
Oh and for the record its "Alberta Safari Company" http://www.detailplustires4x4park.ca/asc.html
cheers
Nice Wayne - The tractor tires don't even look that bad, and if they do the job that's great.
All you need now is 3 point linkage and a plough. :D
:beer:
Very cool. One of these days I will have to make a trip to Lee's park when the Cruiser gang is going. Looks liek Craig had fun too!
What are the specs/brand/make/etc of those tires? What rims did you run them on?
gb
Hi All:
Wayne, it is great to see you up to your usual tricks! :grinpimp:
I always enjoy following your thread here on MUD! :beer:
Take Care!
Alan
so far 4.11 with stock everything except mapped turbo...
i am thinking if this is my next wheeling rig then i will take the 4.56 out of the PZJ75 and swap the 4.11s in.
i have a 2.48 t/case sitting here ready to go
i also have a R141 should i need yet lower gearing...
we will see after May longweekend run if i need the swap or not...
cheers
