I'm looking to buy or trade for an off-road trailer. I'm located in Provo, UT, but often travel up to Idaho and down to Southern Calif. I'll also consider shipping if the deal is right.
I'd also consider full or partial trades for the trailer against my 1964 Scout IH rock crawler. See details below:
Built 1964 Scout International Harvester $6000
PICS
http://www.byuinfo.com/pictures/scout/
VID
YouTube - 1964 400 hp Scout for sale
1964 Scout For Sale, located in Provo, UT. Needs some minor details sorted through (ie wire loom in engine compartment, tighten beadlock rings) and could be an incredible vehicle. Call me for details or post here.
Motor-chevy 350 apx 12000miles. vortec heads ported/polished with staples valves billet steel knife edge(to lower resistance) crank, billet rods, kb hypertectic pistons, hydraulic roller cam, roller lifters, roller rockers, rpm intake, holly street avenger (custom) carb, headers, dual exhaust. This motor is 400 hp balanced and and ready to rumble with a extremely light rotating assembly. You would be hard pressed to build this for less than 12 grand. This motor is awesome and this car is loud and turns heads.
Tranny- chevy 700r4 custom built 2,3,and 4th gear lock up gear switch
NP 241 transfer case rebuilt with slip yoke eliminator kit
Rear high angle driveline with 1ton cv joint
rear dana 60 w/detroit locker, custom heavy duty rear dif cover,
front dana 44, 4.56 gears
hydro assist steering and cutting brakes
Suspension- 6'' spring over lift, Rancho RS adjustable shocks, front scout 2 springs shackle flip to rear, rear 800 scout springs re/arched with double main military eye wrap, heavy duty shackles.
Tire/wheel- 37.14.5.15/ toyo mt with aprx 4000miles on them. rockstopper beadlocks. this is a full set of 5.
Custom front& rear bumper- front shackle mount/tow bar mount with tow bar, rear tire d&c tire carrier/jerry can holder.
Interior- 6 point roll cage, racing seats, 4 point harnesses, custom dash, auto meter electric speedo, auto meter tack with shift light, cd player hurst pistol grip shifter, amp, sub, cb, with all wiring run though roll cage, line-x spray in bedliner tub&top.
Onboard air- york air compressor
Custom rear 15 gal fuel tank
winch not included
Keith 951-691-7604
keithroo@hotmail.com
PICS
VID
winch not included
Keith 951-691-7604
