agreed!A piece of mind is priceless .
At least that is why I maintain my machines.
It's not a binary issue of changing the fluid only if you overheat but never changing it otherwise. There are varying degrees to which one can stress the transmission, which the Toyota recommended service schedule PDF acknowledges by recommending a replacement of the WS fluid every 60k miles if the LC is used for towing.
Seriously, just go download the recommended service schedule PDF from the Toyota owners website. Although Toyota admits the possibility that the fluid needs to be changed only under certain conditions, the very logic that goes into this "change if towing" recommendation is an acknowledgement that WS can ware down. So yeah, the label "lifetime" is quite misleading.
Sounds like you spelled it out if you tow change it every 60K miles. If you don't Lexus does not recommend changing the fluid. I changed mine just to feel good. Mine shifted like butter before I changed it and it shifts the same after. I had the drain and fill done not the flush, safer.
Which means you drained all of about 25% of the total fluid. Seriously, I've spoken to the shop foreman and observed what they do.
Not all dealership employees are elementary school dropouts.
Interesting thread. I'm wondering what degree ofI should be at my independent Lexus mechanic (was a Lexus Master Technician), who yesterday told me the TF was "dirty" and suggested a flush, which I agreed to. Now I feel like I got hooked up and got flushed from my hard-earned $. This is at 65k miles, by the way. He never even asked me if I towed or anything (I don't).
I would be more concerned about the fact that his flush machine had left over fluid and when he put in the WS you got a mixture. If you fluid was dirty you have a transmission problem. I doubt it was dirty. The guy just needed some cash. My Lexus SA recommended I not change the fluid at 110k miles and if I had to service the transmission I should only do a drain and fill since their machine is used with other type of fluid.
I have a 2005 Lx470 with 130K mi. As far as I know the fluid has never been changed. I bought it at 125k mi. It appears the general consensus is to flush the fluid. I guess the drain and refill method is the easiest and you just measure the amount out and fill with the same. Is it recommended to continue with WS fluid or try something like Mobil 1 ATF?
Yea I just looked that up. Mobil 1 is a no go. But it appears Valvoline Max Life Syn and Amsoil are WS compatible. Are there any preferences on use. Toyota brand vs the full synthetic brands?
Valvoline Max Life Full Synthetic ATF - 1 gallon = 17.87 @ Walmart
Amsoil ATL - 1 gallon = 48.70 @ online retailer
Toyota WS - 4 qts = 36.40 @ Amazon
..the Toyota WS some believe may be a conventional..
[Rant] The problem with Blackstone analysis for routine maintenance (besides the fact that we'll all likely be driving different rigs before any meaningful data comes in) is that it is without context. It is simply a comparison of characteristics without a "so what?" conclusion. Useless, except to lighten the wallet. It's great if you want to (in)validate things like head gasket failure, trans fluid contamination after cooler failure, etc. etc. otherwise I learn absolutely nothing by reading Blackstone reports. They don't address the relationship between the elemental analysis and the functionality of the fluid they're testing, e.g. how low is too low? how much is too much? what effect does that have on the main function of oil/trans fluid/anything-else-they'll-take-your-money-to-analyze... Sure, they'll compare it to their database of similar engines/trannies, but again, so what? Their recommendations are always conservative and involve a re-test.Sounds like your more ten competent to do the job. Use the other brand start a thread and update as the miles roll by. Would be a good resource for others. Sample your OEM used fluid as a 130k mile bench mark and send to Blackstone. Then sample the new stuff as the miles roll with Blackstone sample analysis to see how it compares.
This kinda blows my mind. Factory fill performed for 406k road miles, that's impressive. I'd have to check my maintenance notes but pretty sure PO did a fluid change, but I'd be interested to know how many have never touched their fluid and have over 200k miles.My son's 4R made it up to 406K on WS with no change, that's when torque convertor finally gave up.. It was of interest to him, as he is an engineer, involved in transmission design for CAT.
