Work Truck Build Up (2 Viewers)
I’m leaning towards cutting the dump frame out of this truck and eventually putting it in the farm truck that is in the works right meow.
man There are so many tabs needing to get built and welded to axle and frame!
Just need to weld a squeeze on the back of the flat deck and you can tip them stubborn ones up with the dump
jim, you’re alive?
So far, Wu tang flu ain't got me yet
Ha ha, not much, that's pretty much where it stalled. I started doing a few things on my current farm truck build (ill start a thread on it eventually when I get some progress pics from Dan and I have some time), then outside got nice and busy on the farm, and now work got busy and I have a bunch of reclamation work I need to take care of. I will probably get back on it next winter.
Still stalled?
Pretty much. I did a little bit to it before Christmas, but nothing to write home about ;)
yeah, I think if it was a 40 series I might have more motivation to work on it, right now I prefer to do stuff on the farm, which keeps me pretty busy as well. I think if someone came to me with a solid offer, I'd probably sell it as is.
So been plugging away at this thing a little. I’d like to put it together enough to get it to start and drive onto a trailer when I sell this thing ;)
Few more of the progress of patching inner fenders so I can put together the front clip with paint on it in case it goes outside for a bit and won’t rust
Exhaust check ;)
you really should keep it
Ha ha, I should with the amount of man hours I got into it, and it would probably be pretty fun to drive with the front coils, turboed and intercooled 1HZ. But I think I prefer the 40 series ;)
Did some painting. And installed the finished drivers fender a while ago
Then I installed rear driveshaft and swapped out mine passenger door for less used one I got from Brad Taylor when I was in Saskatoon getting parts many moons ago ;)
Speaking of Saskatoon, pulled out and dusted off some bling bling I got from Ens Toyota on that same trip
Continued plugging away at things. Once front clip dries, I’ll be putting it all back together and hopefully starting it up!
