I have a 85 fj 60 that mostly runs ok. I was driving it on a two hour trip and it did fine all the way there and part of the way back. as soon as i get on the interstate it starts sputtering and dying out. It would go if i barely pressed the gas and didn't accelerate at all, but if i pressed down on the gas at all it just started sputtering and shaking the truck. the further i went the worse it got and eventually it just wouldn't go anymore.
It sat for a week before i could mess with it. i put a new fuel filter on it, cranked it, and it seemed to be running fine. but it seems to be sputtering out a little when i drive longer distances ( 15 - 20 miles ). I am pretty sure that if i get in it again and try to take off down the interstate it will happen again.
should i disconnect the char cannister ( or whatever its called) ? i read something about swapping the vacuum lines running to it.
I am also thinking i might pull the internals out of the smog pump, i've done that before on another cruiser and seemed to work ok.
the truck has had an uneven acceleration since i have owned it, as you accelerate it will kind of quicken and slow. don't know if that might be related.
what should i check and generally what are the tricks with the emission system, i don't have to have it tested in my state so i can do whatever to it.
thanks for any thoughts or suggestions.
