Just driving along with my 1-BBL Aisin and it started idling really rough and cut off due to flooding. When I took the top off the air filter it appeared that gas was pouring into the carb from a port just above the throttle plate. It almost seem like the gas was boiling out onto the throttle plate. The gas seems to be at the right level in the carb window so I don't think the float is stuck.
If I crank it up with the throttle wide open it runs rough for a minute then clears up. If I let it idle, it runs smooth for a about 20 seconds and then the pattern starts all over again. Something is stuck or plugged --what do you think?
