I've been trying to sort out some electrical issues on a 65 FJ45 (sat for 10 years but I have driven it 2K miles since) and am finding some very strange stuff. It all started when I tried to add an amp: https://forum.ih8mud.com/40-55-series-tech/265529-amp-question-65-a.html
History:
There are quite a few things going on so bear with me. First of all the voltage regulator was allowing 16+ volts to the battery so I've ordered a new one. In the meantime I'm using a spare out of a 73 and it's limiting the volts as it should. I also tested the alternator and it was only charging at 5 amps so it's being rebuilt. Has a brand new OEM fuse block, good grounds at the starter and battery (I just pulled it all apart again today and they're as good as it could ever be). I currently have a donor alternator in the rig that is not hooked up (just to turn the water pump) so I can move it around as needed. All three wires are seperately covered and attached out of the way.
While troubleshooting the electrical I noticed the AMP meter was loose (not the connections but the mount). The PO had JB Welded some crap on there to hold it in place? I've since rectified the problem (I think) by using some rubber o-rings in place of the insulators that are no longer there which allows it to be tight. The amp meter has always bounced erratically since I've owned the truck but even more so now. Like "omen" style now and then when the alternator was hooked up.
I know, too many things going on. Many parts of the equation can be removed once i have the rebuilt alt and new VR in place. If I could order a new AMP gauge from Toyota I would just to be sure.
So the issue I just found that may explain much of this is...
(With the alternator unhooked) The white/blue wire that goes to the B on the alternator has 12.75volts. Disconnect the negative battery cable and the wire still has 12.75 volts. Turn the key one click to "ON" and the volts go away. Click back to the "OFF" position and the volts go slowly from 0 to .30 over a 90 second period then stops there.
HELP!
History:
HELP!
