The compressor head for the AC. You want to keep the high pressure down under 175-200. In high heat situations, the pressure on the high side will rise and trip the high pressure switch disengauging the AC clutch. This is because the condensor cannot keep up with the heat transfer. By attaching the fan control to this wire it will make the fan come on when the pressures get high thus allowing max air over the condensor. By attaching the controller to the ac clutch, it acts the same by keeping a constant flow of air across the condensor, thus keeping the high side pressures down and the compressor on. Either way will allow much better AC cooling at low speeds.
G
