windsheild bottle relocation
lx450landcruiser
Moderator
Seattle
i got the kit from slee. awsome kit very well made.
any ways theres no pics of one installed that i can find least not good ones. any one have any pics to help me out on the install?
thanks mike
When I installed the Slee washer bottle relocation kit I had two problems which I was able to resolve.
1) When mounted according to instructions the bottle was smashed up against the diagnostic port. I then moved the diagnostic port to a higher mounting position but the bottle still smashed against the port.
2) The cruise control throttle cable was pinched between the bottle and the front relocation bracket.
I solved the first problem by mounting the bottle on the forward side of the rear bracket. This moves the bottle forward away from the diagnostic connector. In order to do so I needed to make another spacer, as the spacer supplied is sized to mount the bottle on the rear side of the rear bracket.
I solved the second problem by making a spacer for the forward bracket to provide more space between the bottle and the bracket, eliminating the squeeze on the cruise control cable.
I made the spacers out of 1 inch diameter delrin rod, which I already had laying around. Use of the spacers requires longer mounting bolts.
Here is a pic.
wow i thought i was just crazy when i mounted mine. I was woundering how i was gonna run that cable since its inbetween the bracket and the bottle. i drilled a notch in the bracket. (sorry christo) and then ruan the cable in that notch that way i could tightn everything down and not smash anything.
everything hooked up and works great.
hey Beowulf do u ever drive that cruiser? ??? or did u just replace every part in the engine bay? ??? :P :P :P :P
He's having it trailered over to my place tomorrow for some more new parts :flipoff2:
I have to wash the driveway down first or he won't roll it off the trailer. ::)
Sometimes....
But I prefer it to be nice clean snow, 2 or 3 feet deep.
-B-
