I’m going to be that guy who brings back an old thread. To be fair this thread had the most info and it helped me but I felt it was left a little open ended.
Per this thread I bought the
Dorman 38480, I lucked out and they were in stock at my local AutoZone. I also got the
3900psi JB Weld ClearWeld from Home Depot. I’m sure there are better or more suitable adhesives but this has been working for me for a day so far. I also scuffed the glass with 120grit and cleaned it well.
Also this
guy on YT has a good video on how to remove the door panel and the glass. It was very helpful for me. Although someone had definitely been in there before as the plastic sheet was gone and replaced with dynamat.
That’s where things diverge. The Dorman clips are NOT plug and play. At least not for the front right window rear clip. The front and rear clips of the front windows are different as the glass has a step in it, so the rear clip has a higher “perch” for the glass. I ended up using the broken clip to trace out where to trim. Photos below. I ended up using the Dorman clip that has the slot. The other clip actually has a threaded hole and would have required more modification.
With the modification I made on the clip (I just used a hacksaw and metal file to shape it) the glass didn’t bear on the bottom of the clip. So I cut up one of the others to make a spacer.
Then I glued it all together with a clamp and let it sit for 10 minutes. Then I reinstalled the window in the door thinking that the epoxy was still a little soft and any misalignment could still be corrected.
Ultimately this was a 2 hour job in my driveway. A lot of that time was running back and forth to the shed to find a different tool.
Tools used:
Trim tools
Phillips screwdriver
10mm socket and extension
Glass scraper/razor blade
Sharpie
Hacksaw
Metal file
Sandpaper
Paper towel and isopropyl
Beer
Photos:
I used the clip in the middle.
Aligning mounting hole and traced what needs to be removed.
Modified clip in position.
The spacer I added to match glass mounting height.
