I’m thinking about relocating the solenoids from my 12k warn under hood and was curious to see pics of what others have done and where you all have put it. The main reason for this would be to help increase airflow to the radiator at highway speeds.
If you search, you will see many others have relocated too, but here's mine.View attachment 1556834
But where do you keep your spare quarts of oil now?!
I did similar with my solenoid box, since it wouldn't fit nicely behind my bumper anyway.
Still fits a quart easily, to the side of the solenoid.You can see it sitting there in this pic:
It will have a negligible effect. If you're having trouble staying cool, there are other places to look for solutions.The main reason for this would be to help increase airflow to the radiator at highway speeds.
I definitely hear what you are saying. My temps will rise to about 205 mid summer when driving highway speeds and driving up hill. The cooling system is all new to include the modified fan clutch...SNIP
Sounds good on the trail, but if you're pulling 205 at highway speed, something's still wrong. If you modded the clutch yourself, might need more fluid. When I first R&R my original radiator, I modded my fan clutch and didn't get it full enough. A few more grams made the difference.
Something is not right.I definitely hear what you are saying. My temps will rise to about 205 mid summer when driving highway speeds and driving up hill. The cooling system is all new to include the modified fan clutch and a recently completed head gasket. The lights and possibly the solenoid on my arb impede air flow at highway speeds. The truck idles and will wheel all day long under 190 on the coolant temp. I’ve pulled the winch and lights off to verify that the truck will stay at 190 on the highway so that is how I came to this conclusion. I thought I would try the solenoid move first as I’d like to keep the lights but what do ya do. I’ve just been watching the temp and running a little bit of heat in the cab and it brings it right back down. It never overheats nor does it make the factory gauge move. I’m just being anal and want to keep my temps below 200.
Yes, just a simple sheet metal bracket. Bolts on with the single existing bolt to the core support, then bent down to catch the solenoid bolt holes.
