Now I have to figure out why I bought a winch in the first place...
Pretty green color on the winch line...matches my nails...
Looks great...it's always good to have another winch on the tail.
Please PM me if you decided to scrap your winch project![]()
I believe I'll be holding on to the winch, even though I haven't needed one.
Actually I did have one hooked up to my ass once when I tried to put the truck end-over.
should n't you move the line guiding plate down so the line would not be touching it (hopefully) when pulling?
Sounds like you're wheeling about as much as me. I've been 2wd for a month and a half- front DS toast and no motivation to get it fixed. In fact, I haven't wheeled since I got my winch, right after the 'Great White Elephant Rescue' of '08.
Looks good.
-Spike
Howdy! While all this is true, how often do you make a perfectly straight, even pull? Most pulls will have the rope/cable rubbing either on the top or the bottom of the fairlead. I have heard that rope does not do much better on roller leads. I have seem some of those so smooth/rusted up that the steel cable couldn't make them turn. I wonder if a textured roller, with well greased bearings, would do any better? JohnAlvin: centered location is perfect for visual but think for a moment how the winch and the line would operate under full load, first winching is dead centered line and the second is when te winch anchored some 30 degrees off center line.
Try to minimize the line rubbing against the fairlead as much as possible! The best position is where the rubbing is minimal. Remember each time the line rubs against the fairlead:
- the line gets used unnecessarily
- the heat is locally generated (rubbing under load) and this destroys line strength
- the fairled is getting worn
