- Thread starter
- #41
OK.. UPDATE...... Installed longer wheel studs and spacers.....everything fits perfect.
the Studs are larger in diameter than stock but the Knurl diameter was the same as stock ".560 inch". It was a straight forward swap out. The rear, I was able to replace the studs without removing the axels, but the fronts I had to pull out the hub to get access to the studs. I have attached photos showing the new studs in place. it was a 4 hr job... The last photos shows the offset and shows that the tire now sticks out a 1/4" outside the body... I think it looks it a little cooler!
