Why you should rebuild your injectors.
Tauranga New Zealand via Vancouver Island Canada
Simple math:
3B Diesel
130,000kms
Before injectors were rebuilt ~ 18mpg (UK gallon)
After injectors were rebuilt ~ 26mpg (UK gallon)
That's a difference of 8mpg, or 5L/100kms.
I average 1500kms/month, and #2 diesel averages 90 cents CDN/L here. This means that I am saving 75L/month, at a savings of $67.50/month, or.....
$810.00 a year in my pocket. :bounce: :bounce:
Good to know :)
Yeah ! How much at your place ? Here in Montreal it's about 40 to 55 $ CDN
Did you change the injector gaskets ? or use the old one ?
I'm only a quater of the way into a tank of fuel after injector rebuild and turning down the fuel. But i'm getting killer milage right now.. as well I should I just creep around ;)
The fuel was actually turned up a touch. Each injector cost about $70 after tax, but I had big problems with the pump caused by myself, that took another $200 before I realized it was a stupid oversight and nothing was actually wrong.
I used new injector gaskets and seals, they're dirt cheap. I also added some Moly to the transmission, and it shifts a lot smoother, perhaps reduced friction?
In any case, the old injectors (one of which I keep on my desk) were totally carbon-ed and sticky...a load of bad fuel somewhere.
Oh, I also added a Racor filter, perhaps an improvment in fuel quality/mileage? Dunno...but I'm loving it.
Hey Wayne, I ran the tank near "E" and filled up yesterday, she took only 65L. I can't believe the gauge is off enough to then believe she has a 90L tank...any possibility the JDM's have smaller, say 75L tanks?
90 L tank on the 70 series even the LJ71 has the same tank... it feels like you can drive forever on a tank of fuel...
and yet i was asked if i can get a long range tank for one...
I need to clean the contacts on my fuel gauge.. It was way passed E so I figured I should fill up. Only 16 usg out of 23 :rolleyes:
What is involved with the injector being serviced is there more to it than simply changing the injector nozzle?
AFAIK shimming to ensure the correct crack open pressure. From what I understand there is no sense in changing the nozzle on IDI nozzles, or servicing the tips on DI nozzles, if the crack open pressure is not correct.
gb
