1HZ Injectors Outrageous Price.
Under my cruiser
Website
www.youtube.com
Hello everyone, I was thinking of replacing the injectors for 1HZ engine, but the prices of OEM injectors are out my financial range. Part number is 23600-19075. I found these injectors for a little reasonable price on Megazip website and upon messaging their customer service to check if those injectors are in stock, I learned those are out stock at least on their website.
My question is, should I just rebuilt the original injectors or buy new one?
Thanks!
Just get new nozzles. If you get OEM Denso units they are quite reasonably priced. But be aware the market is awash with Chinese fakes, so I would only order from a reputable supplier.
eurasia is right, you maybe mistaking the nozzle holders as parts you require, to rebuild mechanical injectors you only need the nozzles, perhaps shims, at worst a spring. The holders should last your lifetime as long as you don't over tighten and strip the thread.
I love the difference in price of servicing mechanical injectors in comparison to electronic injectors, something like 1/6th the amount. Like, drop off your injectors at the diesel specialist, $600 aud for all 6 instead of $3600. Lasts you 100k kms.
Rebuild as long as they haven't been stored with a bunch of water in the fuel system it will be fine. The nozzles are reasonable.
which are usually denso for toyota. Even if toyota has a part number they do use quality products from other manufacturers. Aisin, denso,koyo..and so on. Denso probably has one of the best reputation for diesel components, most reasonably priced too for what they are.
If I am sourcing nozzles myself , I just go straight to denso.
