Why Washer Diverter Valves Fail
OK, since ALL of us will have to replace this little guy sooner or later, I thought I would find out why it fails. Below are pics of the DV's guts. On the left is the diaphragm and on the right is the solenoid. In my case, the solenoid still worked but as you can see the rubber disk on the diaphragm was shot. Instead of blocking the passage of fluid, the fluid ran around the diaphragm through both the front and rear outlets. I suppose time and heat are the two biggest enemies to these rubber disks. -Now you know
BTW, the part number for this valve is: 85321-60050 and retails for around $30
