Did you make any extra backing plates? I need some. Thanks for those pictures and description. Your valve cover looks damn cool.
I have driven over 6000 miles with the resistor mod on mine with absolutely no issues, except slightly better gas mileage and a smoother running engine.
I never performed this mod because I had a pesky egr code, my system was working just fine, I did this to get rid of the driveability problems associated with this system in general and to pick up a little increase in fuel mileage. I have performed this on other vehicles with success before and the 1FZ-FE seems to like it also.
My egr valve and other components are still intact and on the engine for the 2 year testing in my area, just simply disabled by pulling off the vacuum lines and capping them at the throttle body.
I could never seem to get over 12.5 MPG in my truck, just consistently saw between 11 and 12.5 since I have owned it.
The last 3 times I have checked I have gotten betwwen 13 and 14 MPG. Once I even got a 14.8 which nearly floored me.
Like previously mentioned the engine doesn't nesessarily feel much more powerful, just smoother...without the slight lag when the egr kicks in off idle.
As far as a lean condition is concerned, that might be partially true although I have seen no ill effects of this. Of course mine is the OBD I and the OBD II might react very differently to this situation.
Isn't exhaust gas basically inert, having little or no oxygen in it?
If so there should not be much of a lean condition present.........?
I can't find the plug to do the resistor mod - I think the UK trucks must have a different spec - and they are NOT OBDII. Not able to fit Scangauge or anything nice like that.
The Lovely Boyo,
Did you have a check engine light on before you did this mod? What was the result of your mod? Smoother idle? Better gas mileage? Cooler temps?
The Lovely Boyo,
does your cruiser pass aircare with the resistance mod? thinking i might do that n see how it goes. i dont expect it to pass aircare, but at least it'll clear that pesky orange light. did you have a insufficient or excessive flow code thrown and replace suspect parts like vsv, modulator etc?
I wondered why I had been so lucky not to have one of these codes, but obviously my cruiser has carbon build up just like everyone's cruiser.
