I’m waiting to hear back from the company. I’ll give them a call first thing next week. Might as well order a few yards of the material.Is this going to happen? I will just order my own if not. I need this stuff soon as I am almost done restoring my running boards.
Where did you end up getting it from?I just ordered a yard of the material. It's 48 inches wide. I should have plenty extra for a few other sets.
I will report back when I receive it.
Here’s what the remnants of my OEM look like...This should cover it. Would I be safe to assume the pattern goes "parallel" or "square" to the axles or bumpers? Not following the angle of the rocker?
Basically, parallel to the outside edge of the board.Thanks. It is like I thought.
Ill take some!If anyone needs some of this material, I have extra to sell. Would be pretty cheap for enough for 1 set.
If you don’t have enough material for billsboat longs, I could use a set for my shorties. Let us knowI have enough extra to do a pair of the shorties. Might be enough for the long ones, but not sure.
What do you need long or short?
I messed up one of mine too – referenced the wrong long edge as my parallel side. It's not the end of the world, but if you are trying to make it correct to factory, the outside edge of the running board should be the parallel side. Glad I got some extra material from you!I have enough for his longs. I messed up cutting mine out and wasted some vinyl, otherwise I would have enough for a set of shorties too. Sorry.
