While I'm in there
jrmudder92
John R.
Madison, WI
Website
www.instagram.com
so I'm replacing the rack and pinion and both tie rod ends. And all 4 control arms. What else should I do while I'm there.
I'm curious as to why your replacing all this stuff?
I'm curious as to why your replace all this stuff?
Well the rack is leaking badly so need a new one! Also one of my ball joints is bad so Im just going to knock them all out at the same time!
Oh I see, make it like new while in there. You could check the front differential mounts and sway bar links & bushings.
If you have your front end apart, definitely change the front sway bar mount bushings. They are nearly impossible to get to with the torsion bars on otherwise.
