Which way snorkle intake facing?
Well, with the intake facing forward you get a kind of cold air ram effect, which should be good. With the intake reversed you'd get negative pressure at the intake which probably isn't good.
Face it sideways towards to left side of the vehicle. No negative pressure, less dust and bugs getting into it. Keep in mind I don't actually have one :p
I always have mine forward except when it is really raining hard and I know I will be driving 50mph and faster.
I rotate mine to face the rear in dusty conditions ( eg. convoys ) .
In rain and other : forward .
The reason I rotate it back is cause I have a K&N filter . If I know I will encounter a lot of dust ( before leaving home ) I put in a paper filter and leave the snorkel facing forward .
IF you look closely at the intake you will notice that there are channels in the top part of the snorkel. THe tube to connect to the intake is run up inside of that and a lot of the rain is forced againts the wall of the intake and runs back outside of the unit. The opening is also slanted which helps keep out the water. I have driven mine for 4 years now in heavy rains and have never found any kind of moisture in my airbox. It is not a problem, I do find a few bugs and you would be suprised how little dust. When we run dirt road in a group and compare airfilters mine is almost clean when people in the group without snorkles are full of dust.
