Which Side Is Up?
Hogan
Three on the Tree
Forest Lake MN
This is the gasket for the side pannel on my F engine. Does the side with the little bumps go up or down?
It only fits one way Mike.... ;)
"little bumps to the top" :)
Thanks Steve
Just a quick reminder...
Before you install the gasket, maks sure you use a small hammer and reverse ping the metal side cover where the 6x1.00mm bolts go thur or the gasket will contiune to leak.
Marlin
Marlin
You Lost me on that one Marlin??
I believe he means to panel-beat the cover around the bolt holes because the metal is likely to have been "pulled-in" there.
If you don't "re-flatten" the metal around the bolts, the cover probably won't be able to exert sufficient sealing-pressure on the gasket mid-way between bolts ..... if you know what I mean.
:cheers:
On the same theme ---- Where soft cork gaskets are present I like to use loctite thread locker and avoid over-torquing the bolts. (Without the blue loctite, the torque may be insufficient to stop them loosening due to engine vibration.)
