Mine looked like that and it was the return line. Very straight forward, quick. If that doesn't work then do the pump. Start simple : )
There's always one! A leaking seal is a leaking seal, the man asked for a sealant solution, I gave him one!
I can see you now at the side of the road with a puncture, your spare is also flat and you have a can of tyre sealer/inflator, ooooh it's pissing down with rain and I am twenty miles from home I cannot use this repair kit on my Land Cruiser as it is the 'wrong approach'....no wait....it's ok I went to work in the Kia THANK GOD....ppssssssttt!!
Give me a break pleeeeease!
regards
Dave
There is a time for makeshift repairs (Parachute Cord, Zip Ties, Duct Tape, Fiber Fix all in my cruiser). This isn't one of them and neither is brakes. Carry on, and thanks for reminding us to check our spare tire pressure. Prevention is best tool.
Dave, I think North Korea has hacked the forum, we got to leave them alone...
Respect the Kia...
...er is that an appropriate smiley? The last thing I want is someone pointing out there is too much play in the steering Should have poured some brake fluid in the gas tank, that would have it fixed the coating!
I have no experience with Korean diesels, but I wouldn't be surprised if the same thing happened in a German diesel and the engine used the dissolved coating as fuel! My VW diesel ran on lamp oil, I tell you...
It is true if you can get around VW doing the odd 'silly' thing like using plastic cogs with steel cables for window lifts then VW have a good reputation. Had my first car when I was 10 years old, it was a Ford Zephyr and was brilliant......once I had repaired it with the help of a school chum and the ability at a young age to read and understand workshop manuals....god am I really that old? I know it's an old thread but does the rockauto Kit come with directions?The reseal kit is less than $20 from rockauto, you can get hose buy the foot from any parts store, atf is cheap at walmart. You can probably pull it, re seal, and replace all low pressure lines for less than $60
Also, to answer your original question, if it has ATF then use the Lucas atf stop leak. I used this on my wifes truck for about a year. It will slow the leak but not stop it.
Russia...Dave, I think North Korea has hacked the forum, we got to leave them alone...![]()
Does the atf from power steering and tranny both make contact? I ask because I have a bad power steering pump/ box leak and I've noticed a slight leak from transmission. Have been unable to locate tranny leak. Thank you for responses
