Where's the Cabin air filter for a 1995 Land Cruiser KZJ73
Ok... Then it's all Cloged and stuffed Up.More than likely your nose and in your chest (lungs)...
cheers,
george.
I asked because my front Cabin Heater's not blowing out very Hot.. it's luke warm.. and I thought it might be a clogged filter.Nonexistent
Not I think I'll flush the system and replace the Thermostat... Any other Ideas?
Thank You !!I'd flush the system first. Worst case, you will have a clean system with fresh coolant.
Also, could be debris on/around the heater core. A bunch of junk tends to make it's way in there on these 70s after 25 years. Generally this leads to low airflow.
If you don't mind.. can I lean on you for any diagram or instructions for accessing the Heater Core. I have No A/C. Just a front and rear Heater. The Rear Heater work's Excellent.. the front just blows out slightly warm & the Defroster doesn't work well enough to defrost.... Any Help is Greatly Appreciated.I'd flush the system first. Worst case, you will have a clean system with fresh coolant.
I don't have the 75-Series shop manual on me right now but it's pretty easy to pull the metal dash.
Galaxies easier than most other cars from the 90s at least.
Thank You OG... Will doRemoved the dash and everything you see in front of you and the heater core will be there right in the middle, tucked away nice and safely.
It's a 73 model.. but I'll remove the dashboard as best I can. The Heater is located under the dash. It looks basically like a long box with openings on the left. My Model is a LHD... If any of this makes a difference.I don't have it in front me either but I think several links are floating around with pdf copies. I just don't know which ones are still active.
HiI asked because my front Cabin Heater's not blowing out very Hot.. it's luke warm.. and I thought it might be a clogged filter.
Ralf,Hi
Before you start taking your dash apart...
What is actually your issue? Is it air-flow or heat-flow?
The question on the filter points to air-flow, the above statement rather points to heat-flow.
- Air-flow may be affected by blower function, air duct, filters ... where most solutions are in the dash.
- Heat-flow however starts with the hose from engine to heater valve, the valve itself and then heater-lines and -core. Most of that can be addressed from outside, without taking the dash apart: Check flow and maybe flush the heating fluid circuit. Maybe start with that?
My truck is also not good in heating. But I know why: the hose from the engine to the heater valve is not original and has a sharp bend that partially obstructs it.
Cheers Ralf.
Thanks. So #87248&9 are the hoses I should be checking out for kinks?.... Or the one's From the engine to Those hoses?
Ok... I really appreciate the Help. I just looked up the hoses and diagram on MegaZip.. I know what I have to do now.Those are metal pipes. The ones you see coming through the fire wall and connecting to hoses in the engine bay.
