I'm getting ready to install my new OME suspension with MAF U-Bolt Flip Kit. What does the MUD brain trust say about where to put anti-seize and where not to?
That never dawned on meTechnically any lubricant in the threads will increase the fastener tension resulting from a given torque.
As a general rule of thumb, when you use anti-seize, you should reduce the torque spec by about 15% ...
A more specific chart, depending on type of lubricant and fastener material :
LUBRICANT OR PLATING TORQUE CHANGES
Oil Reduce torque 15% to 25%
Dry Film (Teflon or moly based) Reduce torque 50%
Dry Wax (Cetyl alcohol) Reduce torque 50%
Chrome plating No change
Cadmium plating Reduce torque 25%
Zinc plating Reduce torque 15%
I use anti-seize on all fasteners that don't specifically call for a thread-locker, at 15% torque reduction, including U-bolts and spring pins, etc...
I always use it on wheel studs...
Yeah, I forgot to add that little detail.So do I. Never had an issue with the lug nuts coming loose. Just take care to not get it on the conic seating surface of the lug nuts.
I use it on my girlfriend...![]()
