Got to thinking about this.
Rod bolt nuts are not usually locktited and are normally lubricated on assembly. Can't imagine a more critical nut. The difference is that the torque specified is intended to slightly stretch the bolt. This is the "elastic" portion of the bolt's ability to stretch. Loosening the nut results in the bolt springing back to it's original length. If you go too tight then you're into the "plastic" region and the bolt will not spring back to it's original length. In nearly all cases that over-tightened bolt or stud is then junk.
So if there are no other 'locking' methods, then when lubricated the bolt or stud may just need to be taken into it's elastic region. If there is some other locking method, be it a conical seat like lug nuts or a Nylok nut or a cotter pinned nut etc. then anti-seize would be a good call. Particularly in the rust belt.
The way that I look at it is like this:So use it everywhere that doesn't require thread locker? Won't the anti-seize make the bolt / nut more prone to backing out or am I missing something completely?
Nobody got Herpes today.
