Where is the Voltage Regulator??
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
I recently replaced the alternator and it recommended replcing the Voltage Regulator. Ordered the right part from SOR for my 77 and I looked all over. Can't find anything that resembles the new one. The OEM Manual shows the picture that looks like what I got, but doesn't show where it is.
Thanks Bailey, There is nothing there. I was wondering because there are two blank holes that the regulator could bolt to. Could the PO have bypassed it? Would it work that way? Any advise would be appreciated.
OK, I tried tracing the wires down. still need to make sure I got it right. When you mentioned PS Firewall did you mean inside under the Glove Box. I think there are wires going to a similar thing with the sane color code there. It's similar, but not the same thing and the connectors don't mate up. I'll keep looking though.
Ken, it should look like this. It should not be inside the cab.......unless the PO got really creative ;)
coolfj40_1784_35581337
Thanks, It looks exactly like that, the new one.
Don't go by what the wire connectors look like. Who knows what a PO did as far as creative wiring.
I looked where you said and found this device. The bolt pattern is about the same, but the wires going into it do not have the right color code. If this is the right place then the PO did someting to it. Maybe the right colored wires are spliced in the harness. I'll take a look at that this weekend.
Is the item with the light shinning on it directly below the brake booster what you are talking about?
Thanks
I hate PO's
Here is one closer, Is that suppose to be there or is that where the volt regulator is suppose to go. Thanks for your help!!!
BINGO! we got a winner :D
that aint stock, but its the voltage reg, maybe a solid state replacement from? or maybe?
Well now. According to some pages it is an upgrade and I don't need to replace my Voltage Regulator when I replace the Alternator. Now I have another upgrade to post next to the "Original miles' lol. Guess I don't need this brand new Voltage Regulator. I am selling it:
https://forum.ih8mud.com/index.php?board=5;action=display;threadid=13369;start=0#lastPost
I'll sell it for the $26 it cost me and throw in free shipping.
I don't know whether I should be happy about this or not!
Thanks for all your help
Ken
So, your new alternator doesn't require an external VR. THAT must be why you wire directly to the Pos post on the Battery. I'm guessing your ammeter won't work any more.
[quote author=Romer link=board=1;threadid=13354;start=msg123699#msg123699 date=1079670971]
Ken
[/quote]
From the picture, it looks just like the solid state regulator that I have installed in my '68 FJ-40. If that is the case, just leave it alone. I have never cared for the old points style regulators.
[quote author=IDave link=board=1;threadid=13354;start=msg123747#msg123747 date=1079674775]
[/quote]
Dave- According to the 2F Factory Service Manual, that is the way the Alt is suppose to be wired. Must be a change between the 2F and the F.
Ken
OK, so where does the 2F ammeter get wired in? Has to be between the alternator and the battery, somewhere, right?
My ammeter works fine. The ammeter also ties to the B post from the harness. There are a couple of wires tied to the positive lug of the battery, 1 to the Alternator, 1 to the harness. So I would assume that the ammeter is wired in parallel to the batt/Alt connection via the harness.
OK, I thought about it and having the amp meter in parallel doesn't make a lot of sense, it would still work but it would not be acurate and it would probably not allow the regulation to work properly. I relooked at the manual and Dave (Crow) you are right. This is the way the PO had wired it and Ijust put it back. I disconnected the wire from the batt to the alt and everything seems to work fine. I'll drive it for a while and see.
Ken
The ammeter is connected thru the white wire coming from the alternator. This wire also runs to the ignition AM and on to the fuse box.
Does anyone know where the voltage regulator is on the 2004 Toyota land cruiser 1hz Diesel 4.2 wagon ?.. it seems to be puting out 19volts and is now frying both batteries ,,, Thank you
