Not sure if its a one of or not ,but mates 90 1hz 80 series aircond pump and hoses look different to my dads 92 hzj75 hz a/c pump n hoses, the 80 series one looking like the pumps and hoses simular to the 60 series old style look maybe they changed in 91 or something just make sure the brakets pulley etc are the same or suit your year motor, if its a factory difference mate
Dude, according to Toyota Parts DIY, the part numbers are the same from a 1990 HZJ75 to a 1995 HZJ75, so I think you are good to go.
There are three part numbers:
1) Bracket, Idle Pulley (cast piece behind pulley) 88444-60100
2) Bolt, Idle Pulley (adjuster bolt) 88446-60030
3) Pulley, compressor cooler Idle (pulley, bolt, washers, nut) 88440-60040
There are a pair of standard item bolts you can source locally.
I'll fax the local dealer on Monday and get you the Costa Rica prices. If they have them in stock and the prices don't scare you off, I'll buy them and bring them with me on my trip to Socal in a few weeks, then send them to you via UPS.
That work for ya?
Rick
Did a quick search on
ToyoDIY.com
They 1HZ, Hdt as well as FZJ's look the same.
A/C units are at the bottom of the Electrical page, select the models and cross reference.
just test fitted it and the pulley doesn't line up with the compresser
not sure if it's the wrong compresser pulley or idler pulley.
edit: and i just saw on kevin rowland's build that only the hz pump will work. anybody got one?
yeah, my alt does have two belts. i went through some paperwork i have on the 1hz and it says it's either a 97' or 98' model. i'm getting a price on a new compressor, but i know it's gonna be expensive. i've also got an email in to g and s looking for a used one.
mine didn't come with a compressor. the po, who did the conversion told me the 3fe compressor would work, but oh well.
i think i can make a bracket to bolt to the current bracket that will relocate the compressor to the correct position. we'll see. maybe i can find a used one, but i don't know if i can come up with $900. that just hurts.
Hey Roscoe... can you measure from the middle of the AC belt (pulley) to the first horizontal mounting bolt (the bolt that holds the compressor into the cast-iron bracket.)?
According to Sheldon at G&S (and here, we were talking about 1HDFT AC compressors):
"[1HDFT compressor measures] 3.75" from center of front mount bolt to center of pulley.
My 97 FZJ compressor 3.25" center of mount bolt to center of pulley. "
interesting. That's about what the FJ62 3FE-crowd measured; well, they said 2.5", maybe they didn't measure as carefully. Your's looks closer 2 5/8".
Hey Missipboy, you might be able to use an FJ62 compressor (once you find the 1HZ AC bracket, that is)
