I put some cardboard in front of the radiator on mine and it is heating up nicely now, but i will check for the upper thermostat gasket as soon as i get a chance.
I get heat from the dash but it gets considerably warmer when I am moving... If I am idling the temp from the dash drops until I start moving again.
I was amazed to find I had any air flow once I saw all the stuff covering the intake for the blower motor. The fresh air intake is located behind the windshield wiper motor under the hood. I just used a shop vac and some contortion moves to get my hand in there to pull stuff out. That's a no-cost fix and can make a difference on air flow.
Yup, you get to the intake right behind the wiper motor. The arm pops off the motor. It will probably feel like it's going to break but it pops out.
Guys...if you are blocking off the radiator to get heat then it's logical to supsect that the thermostat needs to be replaced along with the "o" ring and gasket. You should not have to block the radiator on a gas engine to get heat.....unless you are in conditions like Canada or Alaska...
Since you have heat now after blocking the radiator...that tells you that your "heat system" does function.
Chanage the thermostat, gasket and o-ring.
++++++ CLR +++ works great alsoMuriatic acid works to flush the core. Info on how to do it has been posted in the past.
In my case, when I am driving. The guage regesters less than a 1/8th of a inch on the stock temp guage. (not very much heat)
If I let the car sit in the driveway running. The guage will reach the middle of the stock guage. At this point I have plenty of HEAT.
Once I start driving the guage drops down to the less that 1/8th mark and poor heat.
I had concidered the cardboard idea. (I am sure it would work)
I don't have any idea. Do thermostats go bad and allow to cold a engine temp? I was thinking my radiator is just to effictive. I rarely excede 50 mph. Mostly drive a slow speeds, and lower RPM
Guys...if you are blocking off the radiator to get heat then it's logical to supsect that the thermostat needs to be replaced along with the "o" ring and gasket. You should not have to block the radiator on a gas engine to get heat.....unless you are in conditions like Canada or Alaska....
Thermostats do go bad. Its an easy fix and not expensive. If my heater did not work that's one of the first things I'm going to do, if not just to verfyt that its working. Many people leave off the "o" ring when they replace the thermostat as...has been dicussed here on the forum many times. I suspect some of you guys don't even have a thermostat.
Don't listen to people who advocate not running a thermostat...my first question to someone like that is "Why does every OEM MFG on the planent install them, and then my second question would be...WHen its freezing @$$ outside how do you expect to get any heat.
Personally I figure out in a short period of time why I'm freezing..usually its somethign to do with the cooling system and not the mechanical components under the dash. If your truck does not even reach operating temp going down the road...that's a dead clue that (1) you don't have a thermostat or (2) your o-ring is missing (3) your thermostat needs to be replaced..
The main function of the thermostat is to mantain a certain temp range for the engine to operate. Its not good at all for the engine to run too cool. and also on the same thought line, of course its not good to overheat the engine. If you do not have a thermostat or its stuck open... your coolant continually circulates through the system without ever building any heat and so the result is that you freeze your @$$.
Potentially you could have air in the coolant passenges or low on coolant. But I would bet a new thermostat +gasket+o-ring will solve your issues, or at least get you to where you can see what the real issue is. Both heater hoeses that feed the heater core should be hot to the touch when truck is fully warmed up and the heat is turned to max hot.
The heat has never been "hot", I just assumed it was one of the idiosycrincies of the rigs
