I am looking to buy a set of good used 40 axles for my cruiser. I received an email from an individual who had a pair and said they were already cut and turned for an axle over (which I need) and he said the rear was welded. My question is should I purchase an axle that has been welded? I know 40 axles are pretty tough but I have heard some bad stories about welded diffs.. As I have heard plenty of people say that they do fine. Does anyone have experience with welded 40 axles? I also have a strong SBC and 38's. Just looking for some input. Thanks to everyone for the always helpful comments.
Alex
So are you getting later model knuckles with the larger pattern, or are you getting someone else’s problems they no longer want to deal with?
Are you getting Toyota brake components, or a drum brake axle that someone installed GM or some other disc brake components onto an axle that is still running the smaller, outer drum brake axle garbage and the smaller knuckle studs/pattern?
Do you
KNOW the guy you are getting these pieces from?
Do you have pictures of these axles?
So you have a V8 and 38 inch tires. There are so many variables with this, and to complicate things further, there are a litany of options that you will likely want to install while you have this axle out, including, but not limited to:
New knuckle seals/bearings/gaskets
Brakes/wheel bearings/seals
Marlin inner axle seals
30 spline Longfield axles
Long Chromo drive gears
Front range knuckle studs
Front range lockout studs
As far as the welded rear is concerned, they can last a long time, or, they can fail strait-away; all depends on who did the melting of the metal, and how they did it.
