What's this hose for?
Discussion in '60-Series Wagons' started by paulj, Jul 6, 2005.
  1. paulj
    paulj
    328
    4
    Dec 18, 2002
    Dallas, TX
    Last night, as I was trying to get my air cleaner cover off I pulled this hose off.
    Actually, I pulled the small piece of metal tubing that it's attached to off. What's the hose for, and how do I reattach the piece of metal tubing? It's not threaded, and looks like it was tack welded on. Don't know if that's a stock setup or not.
    The hose has Gates C9070804 B200 written on it. The tubing is 1/4" ( 6 1/2 mm) O.D. The tape on the end was put on by me trying to make it slightly bigger to get it to stay in the hole, but it didn't work.
  2. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    7
    Feb 5, 2005
    off the top of me head
  3. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    It might be hard to reattach the metal tube if it broke off. It just supplies fresh filtered air to the valve below. You want to plug the hole if you can't reattach it so dirty air is not getting sucked in.
  4. paulj
    paulj
    328
    4
    Dec 18, 2002
    Dallas, TX
    What's the valve for?
  5. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    7
    Feb 5, 2005
    it's on the smoged and un-smoged version
    its a vcv "vacum control valve"
  6. paulj
    paulj
    328
    4
    Dec 18, 2002
    Dallas, TX
    Thanks. My truck's an '82 (forget which month), but I've only got a couple of years to go before it becomes smog exempt. The bottom part of that diagram on the left looks like a plate of spaghetti.
  7. polarweasel
    polarweasel Where's mah cruzah?
    991
    2
    May 6, 2004
    Vancouver Island, BC
    And if that falls through, I've got one... I'd want a bit more than $10 for it, though, like maybe $40. :)
  8. Aseif007
    Aseif007
    971
    12
    Mar 13, 2004
    Northern California
    "My truck's an '82 (forget which month), but I've only got a couple of years to go before it becomes smog exempt."
    Wishfull thinking. I thought they put an end to that. 1975 is the last smog exempt year and I don't think it is going to change to 1976 in 2006.
  9. Tinker
    Tinker
    2,865
    9
    Apr 15, 2004
    Larkspur, CO
    You can re-attach the tube with epoxy or JB weld.
  10. paulj
    paulj
    328
    4
    Dec 18, 2002
    Dallas, TX
    Maybe in California, but not here in the good ole Lone Star State.
  11. Ming89FJ62
    Ming89FJ62 I smell bacon GOLD Star SILVER Star
    1,548
    280
    Jul 31, 2002
    Palatine, IL
    Someone double check but it looks to me as if the hose that paulj is holding would be connected to the filter in the A/C and that would mean that it would be attached to the top of the distributor not the VCV. What do you think?
    Harry
