Okay so after a trip up the beach my LS swapped 80 has some issues. Whenever I engage the CDL and get up to speed normally 3rd or 4th gear then let off or clutch in there is a bad grinding noise coning from somewhere in the drive line. I’ve drained the oil from the front diff and it was clean as no metal, the front prop shaft slip joint uni joints are fine. So I was thinking it must be the transfer case or gearbox but then if I remove the front prop shaft and engage the CDL the grinding noise goes away and when I’m going around town with just the rear wheels engaged it’s fine.
I’m thinking it’s the transfer case but any other ideas??
