Chalk test and figure out your own ideal PSI. There is no right answer. E rated tires are made for an 8,000 lb diesel truck.
Higher load rating doesn't mean that you need higher pressure, it means the tire is made to handle higher pressure. For ride quality's sake you can actually run LESS pressure in a higher load rated tire (E for example) if you are not hauling anything. If you over inflate you will destroy your tires over time.
I have a set of KO2s in E rating... I hate them but they came with the rig and do not need replaced. I run like 25 PSI. Tire still barely flexes or takes up any bumps in the road.
