The $60 ish ones?
That price is probably right back when I bought them. I don't know what they go for now as its been a few years without issue.
The $60 ish ones?
Im in same boat going to use the one man bleeding set up Ill post a vd on how to and if it worked.No, I have not. It sounds like I should though...
That would be great, I'm sure that would help me as well as others.Im in same boat going to use the one man bleeding set up Ill post a vd on how to and if it worked.
soon Ill put the video up on my land cruiser youtube channel.That would be great, I'm sure that would help me as well as others.
I don't see how anyone could screw up a caliper rebuild. They are very simple devices and parts can only go together one way.Alternatively, save yourself a lot of time and go with remanufactured Centric caliper assemblies. I have it on excellent authority that it is all too easy to screw up the rebuild, and any little mistake doubles the cost and Triples the time. So I said no thanks to rebuild.
Where do you get the rebuild kits? Is it a Toyota part that can be purchased from a vendor?I don't see how anyone could screw up a caliper rebuild. They are very simple devices and parts can only go together one way.
I do not question the wisdom of my Cruiser Sensei. I just do what he tells me. (Mostly.)I don't see how anyone could screw up a caliper rebuild. They are very simple devices and parts can only go together one way.
UPDATE: Sensei say... O-rings not seating properly, not dealing with rust, not using sleeves when needed, not bore-honing the sleeves. Oh, and unbolting the halves...I do not question the wisdom of my Cruiser Sensei. I just do what he tells me. (Mostly.)
Just used those last week to bleed my Napa rebuilt calipers.If you don't have the vacuum, I have had great success with speedbleeders on my 97. They have check valves built in that don't allow air/fluid back into the caliper. Here is a link from Summit.
1997 LAND CRUISER Russell Speed Bleeders 639560
Thanks for the part numbers!I bought Napa remans, semi-loaded eclipse calipers.... front and rear....stops like a dream, bout time.
SE-2204
SE-2205
I stopped using the 100 series front brake pads, and went back to 80 series, which fit much better...
While I agree the parts are pretty straight forward, other processes are not. Not everyone will have access to a cylinder hone to clean up those pitted old bores. Lots of times the pistons themselves are pitted and they generally aren't found for cheap.
While I haven't rebuilt cruiser calipers I have done several in my day. It can be time consuming and there are often surprises. At the price Napa charges for remaned unit it's hard to go wrong there. Hell at that price you can almost afford to carry a spare pair around.
It all comes down to maintenance. I flush brake fluid and bleed brakes about every year or so. There is little to no corrosion even in my 20 year old calipers. For me, rebuilding calipers is the way to go. YMMV.While I agree the parts are pretty straight forward, other processes are not. Not everyone will have access to a cylinder hone to clean up those pitted old bores. Lots of times the pistons themselves are pitted and they generally aren't found for cheap.
