Stuck people with trailers no less
Gonna go back through the bolts on everything and keep fiddling. Last major piece before Cruise Moab.Did you get lucky and have this tech assigned or did you request a tech with prior 100 experience?Finally pulled the trigger on a new windshield. I've had bad luck with a few local glass shops. This mobile tech with Safelite was out here from Spokane and had done the 100 series before. He did a good job. But also mentioned the guys in the shop here in Bozeman are pretty green. I'll request his mobile service for another car later this month, to avoid the newbies.
Got lucky.Did you get lucky and have this tech assigned or did you request a tech with prior 100 experience?
Yep. It’s been done.Piggy backing on this conversation. I need a new screen for my '62 and am hoping I can also repair any rust or damage that might be under there. Anyone know if I can get the glass taken out one day and then have the new one out in later on?
FYI: most shops will refuse to put the factory sealant inside the older style sandwich gaskets on 80 series and earlier like the FSM recommends which may lead to a water leak and/or windshield frame with floor rust. The new generation of techs think the rubber seals by itself. It was not designed this way. The old school guys that installed these correctly back when they are new are quickly disappearing. If anyone locates a glass shop that will install the older windshields correctly per Toyota FSM please post up. I had this happen a little over a year ago and fortunately we discovered it quickly but my family were scrambling to pull the seats and carpet to dry out and avoid damage. Not fun.
