what engines will work in a PlayDo? (1 Viewer)
crushers
post ho
Derwent Alberta
playing around this morning i thought i would do a search for what engines use the A34* tranny.:idea: this is what i found:
A3xx
FR Transmission
A340H
4 Speed Automatic Transmission (4x4)
Applications:
  • 1988-1995 4x4 Trucks w/v-6
  • 1990-1995 4Runner (4x4)
  • 1998-2005 Toyota Altezza Gita Wagon (GXE15W and JCE15W)
(Gear ratios 1st-2.80, 2nd-1.53, 3rd-1.00, 4th-0.71, Rev.-2.39)
A340E (30-40LE)
Applications:
  • 1987-1992 Cressida (30-40LE)
  • 1986-1998 Toyota Supra non-turbo
  • 1987-1998 Toyota Supra turbo
  • 1995-1998 Pickup 2.4L I4, 3.0L V6, 3.4L V6 (Tacoma)
  • 1993-1995 T100 3.0L V6
  • 1993-1997 Previa 2.4L w/supercharger
  • 1991-1997 Aristo 3.0L I6 Turbo
  • 1992-2000 Lexus SC 300 3.0L I6
  • 1990-1995 Crown Majesta 3.0L I6
  • 1994-2000 Toyota Soarer 3.0L I6 (2JZ-GE)
  • 1989-2002 4Runner
  • 2001-2004 Sequoia (4x2)
  • 2000-2004 Tundra (4x4)
  • 2005-2007 TOYOTA COMMUTER 2.5L DIESEL
Ratios 1st:2.804 , 2nd:1.531 , 3rd:1 , 4th:0.705, Reverse: 2.393
A340F
Applications:
  • 1995-2003 4Runner (4x4)
  • 2000-2004 Tundra (4x2)
  • 1985-1988 4-Pickup (4x4)
A341E
Applications:
  • 1990-2000 Toyota Chaser/Mark II/Cresta 2.5 GT/Tourer V (1JZ-GTE)
  • 1991-1997 Toyota Soarer 4.0L V8
  • 1993-1995 Lexus GS 300 3.0L
  • 1992-1999 Lexus SC 400 GT-L V8 cdn spec.
  • 1990-1994 Lexus LS 400 4.0L V8
  • 1990-1995 Toyota Crown Majesta 4.0L V8
  • 1992-1998 Volvo 2.9L I6 (AW30-40LE)
1st Gear 2.531 2nd Gear 1.531 3rd Gear 1.000 O/D Gear 0.705 Reverse Gear 1.880
A341F
The A341F is an A340F with locking/unlocking transfer case differential to allow an AWD mode on the Sequoia.
Applications:
  • 2001-2004 Sequoia (4x4)
A343F
Application:
  • 1993-1996 Land Cruiser Prado (3.0l)
  • 1995-2001 Land Cruiser
  • 1996-2002 Lexus LX 470
SOOOOO...
as long as you have the bell housing, torque convertor and engine wiring and ECU then you "should" :hmm: be able to install these into the LJ78...
<discuss>:confused:
Let me guess, you were setting around waiting for the coffee to kick in and got bored.:) Why you think the LJ78 needs a replacement engine is beyond me ( remember glass "half full"):)
.......1978HJ45
nah, i have a auto from a dead 78 that i am selling and thought i would check to see what all ran this tranny and found that list... quite a variety to chose from.
A341E
Applications:
= 1UZ-FE 32-valve quad-camshaft 4.0 L (3,968 cc/242.1 cu in) all-alloy V8.
Toyota UZ engine - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Toyota_3UZ-FE_engine_001.JPG" class="image" title="3UZ-FE"><img alt="3UZ-FE" src="http://upload.wikimedia.org/wikipedia/commons/thumb/4/49/Toyota_3UZ-FE_engine_001.JPG/250px-Toyota_3UZ-FE_engine_001.JPG"@@AMEPARAM@@commons/thumb/4/49/Toyota_3UZ-FE_engine_001.JPG/250px-Toyota_3UZ-FE_engine_001.JPG
In its standard, original trim with 10:1 compression, power output is 191 kW (256 hp), torque of 353 N·m (260 ft·lbf).
The engine was slightly revised in 1995 with lighter connecting rods and pistons and an increased compression ratio to 10.4:1 resulting in peak power of 195 kW (261 hp) and torque of 363 N·m (268 lb·ft).
In 1997, Toyota's VVT-i variable valve timing technology was introduced along with a further compression ratio increase to 10.5:1, bumping power and torque to 216 kW (290 hp) and 407 N·m (300 ft·lbf). In the GS400 application, output was rated at 300 hp and 310 ft-lb of torque.
I'd like to put one in an LJ/RJ-70 (Bundera), light duty SWB cruiser.
Here is one in a heavy duty cruiser...
https://forum.ih8mud.com/70-series-tech/64321-4-0l-v8-1uz-fe-land-cruiser-uzj79-4.html
attachment.php
Thanks!!! Very interesting. Gives us Playdo owners a few options:hmm: Might have to try one out just because.
Take Care
