Can somebody tell me what a tune-up consist of? What exactly is done? Some say spark plug replacements and some say more. Anybody??
The definition varies. The big drivers are the year, miles and what has already been done recently.
Basics are plugs, cap, rotor, inspect & lube the drive train (OIL, Lube Filter) (engine, transmission, transfer, drive shafts & differentials), check the brake pads & rotors, check the fluid quantity and quality in the brakes & steering, check tire preassure & wear & rotate, change or clean (some factory ones) the air filter, check & top the radiator with matching coolant, change the wiper blades, vac the interior, wash it.
The advanced class gets to throw in testing for driveline slop/clunk, wheel bearing tension, head gasket symptoms with Blackstone reports, changing the fuel filter, cleaning the sock, checking the AC charge, completely flush and fill the coolant system, check the toe, check rotor run out and lube the antenna.
What did I miss?
use bosch wires if possible.
I agree the the "Grench". use bosch wires if possible.
What did I miss?
When my FZJ goes in the shop for work, she gets an engine diagnostic (w/print-out)... before anything else happens... (even though I do my own tune-ups)
As for spark plugs/wires - Toyota or NGK.
Could you say what is on the print out from the diagnostic test and what do they charge for it (assume it is done by a Toy dealer?)?
(So this is old..)What is wrong with bosch wires? I'd bet that all aftermarket wires are going to meet the ohm specs.
I replaced some spark plug wires on my lexus ls400 with some duralast wires (autozone)the other day and the car runs good and probably will for 100,000 more miles. There is no sense in paying inflated prices for oem wires. There is no sense in replacing wires which meet the ohm specs unless something else is wrong with them.
