- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,206
Looks great!
What size are those rims? Backspacing?
Looks great!
So I am starting to put panels on and already finding out that I may have to redo the way I have the wits End qpm. Just move around the fuses and maybe the Whelen relay controller. But I may just cut out a huge removable panel to ease access. But I will just start assembling things for now to get a feel for where I want things. Then once I am comfortable with the layout and how things work I will tidy up the wiring. Anyhow, this is the Whelen relay control panel up by the mirror.
View attachment 1838769 View attachment 1838770
I may even go ahead and stick the headliner back on now. I think I will stick the CB and Ham in the center console.
The Relay controller shows an indicator LED when the circuit is on at the relay controller and at the control unit up front. If there is a fault, the one at the relay controller should show a blinking LED.
They dont dim, but in person they are not that bright. I left a bunch of slack in the cable incase I end up having to move it.Do those lights dim at night? Otherwise you should consider mounting them lower. I have a three gauge A pillar pod, I dislike driving with it on at night, rather not be able to see the gauges than have the light in my view for night driving
Until you snap a zerk off on a rockNew Napa (SKF) u joints for the front driveshaft. No more dropping them to grease or trying to get into them with special attachments on the grease gun.
View attachment 1839528 View attachment 1839529 View attachment 1839530 Forgot how beautiful new Toyota belts are. Took care of some belt noises.
@248,8xx mi.
What year Sequoia?A horn from a junkyard Sequoia is plug and play after reclocking the bracket. I did one to test first and may go back to get another, but the two tones are attention grabbing.
A little touch of OCD there with lining up those belts. I wonder how long they stay aligned and how crazy it will drive you if the slip out of sequence![]()
This was an 05.What year Sequoia?
Any input is welcome. But I think I got it.Decided to pull apart the Supercharger to rebuild it replace bearing oil and coupling. Im a tad nervous but its on now. making a video along the way for bettView attachment 1839738 View attachment 1839740 er or worse.
Bought a little Miata to get around town. It’s so much fun to drive and it’s amazing driving 275 miles then putting 8 gallons of gas in it to fill it back up.
This will give me the opportunity to do some stuff to the 80 I have been holding off on as I need it ready to go everyday for school.
Basic idea is
New seats
Fix sunroof rattle
PHH finally
New heater valve
Deflare and weld the holes
Maybeeee new front and rear bumper with winch
Nothing to crazy it’ll be nice to be able to take my time with it though and do it right
It was about 6,000 ft on Thursday. Friday it turned to rain, snow only at the pass ~8,000 ft. Quite wet too..What elevation was the snowfall down to?
