Probably considerably cheaper than finding a ‘78 roll bar that already has mounts![]()
Red Line Roll Cage Kit 3-Point Seat Belt Brackets
Red Line Roll Cage Kit 3-Point Seat Belt Bracketsredlinelandcruisers.com
I mean I googled this. I’m sure it wouldn’t be too hard to fab one if you really wanted to do that route either. Mine is bolted to the body
thanks boss, that may be a good and affordable solution to it. appreciatedProbably considerably cheaper than finding a ‘78 roll bar that already has mounts![]()
thank you much, please send some pics.1974 here, too. I put the top bracket on the tab shown on the top of that roll cage. You'll need a longer bolt, and it won't sit horizontal or pivot, but the angle it kicks it out at should work when the seatbelt is on. Mine doesn't retract well unless I help it, but it's not a big deal. I made a lower mount for the retractor out of some angle iron from Home Depot. bolted it into the lower roll cage mount. I can take pics later if you want them. Nothing fancy, but it works. Only important part is to keep the retractor perfectly horizontal for the catch to work properly.
