The F and 2F are tractor motors, not hot rod motors. Put a 383 or a 400 in the LV if you want a hot rod motor...
I've tried to make a 2F into a hot rod motor with disappointing results, including balancing the flywheel and connecting rods, customs racing pistons by Ross Racing pistons (yielded 9.5 to 1 compression), porting and polishing of head, porting and polishing intake, stainless steel customs valves, Mark's off-road carb, headers, 90 lbs valve springs to eliminate valve float, etc.... Wasn't worth the money or my time (except mark's carb).
If you choose not to read technical posts, then you won't learn anything. Search is your friend, use it, use it, use it. I could ask hundreds of questions on MUD, but 9 times out of 10 they are already covered. Your question has been covered in great detail.
